67 427/400 w/ AC Vacuum Hose - NCRS Discussion Boards
  • Stephen G.
    • January 1, 2002
    • 303
    The A/C system has a vacuum take off on the rear of the intake manifold (passenger side) just under the # 3 carb. It runs behind the engine and thru the firewall.
    My original (I think) hose is ribbed. Long Island and others indicate a white stripe My hose is dry rotted and I need to replace it.
    Any input from original car owners?
    Steve Gansky
    Newtown, (Bucks County) PA
  • Larry M.
    • January 1, 1992
    • 2688
    Re: 67 427/400 w/ AC Vacuum Hose
    I would also check DR REBUILD catalog or website. He normally has the best rubber products and hoses for our cars, and also describes what stripes or ribs are typical.
    Larry
    EDIT: DR's catalogue shows this hose as all black, possibly ribbed. The hose from the vacuum valve on the inside heater box to the water valve on the engine compartment heater hose is shown as black with white stripe. FWIW.
