Garage Floor - NCRS Discussion Boards
Garage Floor
  • Jaime G.
    • April 1, 1988
    • 480
    Re: Garage Floor
    I agree with Dick. Light broom or rotary trowel.
    just enough to give it a bit of texture for the epoxy to adhere to.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17549
      Re: Garage Floor
      Don,
      Best to use a rotary trowel as Jaime said. A lot of concrete finishers think sidewalk finish when talking a broom finish.
      Smooth, but not slick finish is what you want. If the finish is rough, the epoxy will magnify the roughness.
      Also think twice before using any color chips or sand. Color chips and sand will leave a pebbly finish and those are hard to clean up.
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Tim L.
        • January 1, 2005
        • 141
        #18
        Re: Garage Floor
        Don, great to hear you are going forward with the garage! What's the size? Have you considered putting a drain in?
        Tim
        • Don L.
          • August 31, 2005
          • 1005
          #19
          Re: Garage Floor
          Originally posted by Gary Chesnut (5895)
          Don,
          Gary
          Gary's right on the added difficulty when cleaning a textured floor vs a plain finish. A smooth floor however, has significant slip risk. Even the textured flooring gets slick when wet. I use the old fashioned "rope mop" and a floor squeegee, which gives me no trouble. The color flakes hide dirt. They do make finding dropped items more of a challenge, however, I haven't lost any so far...
          Don Lowe
          NCRS #44382
          Carolinas Chapter
          • Chris S.
            • January 1, 2000
            • 1064
            #20
            Re: Garage Floor
            Expoxy Coat !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
            I love it !!!!!!!!!!!
            I put solid wheels on my jack - no scratching
            I drop stuff on it all the time - doesnt do a thing to it
            Brake cleaner - no problem
            Brake fluid - no problem
            my wife and I did mine - second time I had did it - first round was PPG Aqua Pon
            Expoxy coat - easy to do - easy to clean
            1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
            Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
            1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
            1957 Corvette - FI 3 sp - Black and Silver
            • Bruce B.
              • May 31, 1996
              • 2930
              #21
              Re: Garage Floor
              I agree with Paul J., concerning epoxies.
              I used a water based spray on coating and it has been fine for 8 years or so. It keeps the dust from appearing and can be recoated anytime.
              No it is not solvent resistent but so what, if solvent (gas, brake fluid, etc) gets on it you wipe it up and respray if you want to.
              My garage is a working garage and the floor coating allows for easy cleaning of dirt and stuff but again is not solvent proof.
              • Chris S.
                • January 1, 2000
                • 1064
                #22
                Re: Garage Floor
                Don,
                Gary
                Sorry - I strongly disagree - the epoxy will smooth out any inperfections
                We just did my fathers 1000 sq ft garage and he's floor had cracks etc... in it - the epoxy coat - totally smoothed out floor
                it is self leveling.....
                as far as color chips - they are inbedded in the floor and dont stick up out of the floor
                I swifter mine and wet swifter it and is very smooth
                super easy clean up.
                • Brady C.
                  • November 1, 2004
                  • 112
                  #23
                  Re: Garage Floor
                  I went with Sherwin Williams Amor Seal (6) six years ago over a floor that was an oilfield machine shop. Muratic acid washed and two coats. Still holding up well today and ask Gary indicated, less than $1.00 per square foot so rather inexpensive to obtain professionally finished floor. No tire marks, peeling, etc.
                  Brady Como
                  #42793
                  Brady Como
                  #42793
                  • Gerald C.
                    • June 30, 1987
                    • 1273
                    #24
                    Re: Garage Floor
                    Has anyone heard of "Flexmar" coating for the garage? I saw it at a home show in Omaha last week.
                    Jerry
                    • Dick W.
                      • 10483
                      #25
                      Re: Garage Floor
                      Jerry
                      I doubt any product at a home show has the durability of products such as Armoseal. I have not seen a water born epoxy hold up as well as solvent based either.
                      The SW product is what Henricks Motor Sports uses in their shops. Very tough product, not cheap though
                      Dick Whittington
                      • Kenneth S.
                        • July 31, 1981
                        • 302
                        #26
                        Re: Garage Floor
                        If there are oil spots on the original floor, how can theybe removed or neutralized before painting with Armoseal, or is that a lost cause and the paint will never stick where the oil is?
                        • Dick W.
                          • 10483
                          #27
                          Re: Garage Floor
                          Wash with TSP, scrubbing the oily spots hard until water will not bead, then etch with muriatic acid, rinsing thoroughly then let dry before painting.
                          Dick Whittington
                          • Robert K.
                            • July 31, 1984
                            • 213
                            #28
                            Re: Garage Floor
                            One item no one has mentioned is spalling or scalling. One cause of these is a plastic layer under the concrete. Interestingly enough, I have it on my driveway but no my garages. The garages have plastic under them and the driveway doesn't. Another cause is sealing the concrete prior to it's curin (drying). This was my mistake. It was recommended by my contractor, but was a mistake. At the bottom of each spall is a pea gravel rock, so I believe it maybe the pea gravel instead of bluestone. If you garage is heat all winter then disregard the above. Spalling only occurs during freezing/thawing cycles.
                            • Don L.
                              • August 31, 2005
                              • 1005
                              #29
                              Re: Garage Floor
                              I didn't mention the minor spalling I had on my floor when I posted earlier to this thread. I did have some. It seems that the spalling I had was where snow melts off the car when parked. Michigan roads are salted so I suppose the spalling was ceated by melt/freeze of salt and ice? Dunno.
                              When my contractor did the grind pass on my floor to begin the process, the spalling was eliminated. In my case, the depth of the spalling was shallow and about equal to the amount of material that the grinding took off the floor, so it all got smoothed out. Even if there had been slight difference in height, the epoxy that went on my floor would have leveled it away.
                              I don't know if shot blasting would smooth spalling or not. Perhaps this is one advantage of grinding????
                              Don Lowe
                              NCRS #44382
                              Carolinas Chapter
                              • Dick W.
                                • 10483
                                #30
                                Re: Garage Floor
                                Robert Keese One item no one has mentioned is spalling or scalling. One cause of these is a plastic layer under the concrete. Interestingly enough, I have it on my driveway but no my garages. The garages have plastic under them and the driveway doesn't. Another cause is sealing the concrete prior to it's curin (drying). This was my mistake. It was recommended by my contractor, but was a mistake. At the bottom of each spall is a pea gravel rock, so I believe it maybe the pea gravel instead of bluestone. If you garage is heat all winter then disregard the above. Spalling only occurs during freezing/thawing cycles.
                                From what you are describing, the finisher brought too much "fat" to the top. It is very easy to bring too much pure cement to the top of your slab when finishing, makes a very slick looking surface but not very durable.
                                Tom Marcucci, a frequent poster here could probably tell you exactly what happened to your slab. That is his field of expertise, among other things
                                Dick Whittington
