Cleaning garage came across a A/C compressor that had a note attached "1955 bel air" don't know where I obtained this from but was wondering if any of you number gurus could decode them for me. On the side is attached a small metal tag with 54 NC 3558 MODEL 6550133. On the cast iron base of the compressor are the numbers 6555302 below this R 11 then below that H 20 2. Any help? Thanks ahead of time for all responses.
A/C compressor ID
Re: A/C compressor ID
6550133 is in the 63 AIM for option C60. I have to look more at the 54 NC 3558. The compressor on my July car is 71 NC 6731 and the date is D 19 3. The same compressor was used on the 63 Cadillac. Saying that you probably have a compressor from August 20, 1962. I believe the first production 63 C60 cars started in March of 63. I'm sure there were others prior to that but that would be hard to prove.Cleaning garage came across a A/C compressor that had a note attached "1955 bel air" don't know where I obtained this from but was wondering if any of you number gurus could decode them for me. On the side is attached a small metal tag with 54 NC 3558 MODEL 6550133. On the cast iron base of the compressor are the numbers 6555302 below this R 11 then below that H 20 2. Any help? Thanks ahead of time for all responses.
My thoughts, the compressor you have was destined for a 63 GM car that has AC, but given the 6 month rule, a bit too early for a Corvette.
But hey, If you have a 63 Corvette with AC and need a compressor, this is a fit, just the date is off.
