1967 Vinyl Hardtop Preservation - NCRS Discussion Boards
  • Rob A.
    • February 8, 2011
    • 135
    Knowing that white is not correct and considering that the car is all original I decided to try and remove the dye. As you can see from the pictures it came out well.
    • 6940
    Re: 1967 Vinyl Hardtop Preservation
    Rob, What did you use to remove the dye? Looks like it did not destory anything. I would think once any type of solvent was applied it would destroy the top.
    • Rob A.
      • February 8, 2011
      • 135
      I used deluted acetone. As I would get the dye removed I would follow with a thorough cleaning with warm water. The original vinyl underneath looks great and was uneffected.
