Restore or buy new AC blower motor? - NCRS Discussion Boards
  • Claus S.
    • December 30, 2010
    • 414
    Re: Restore or buy new AC blower motor?
    Is there no company that sells the evaporator foil plate/decal for a 1964?
    I have been searching all over with no luck finding the decal for a 1964. Only found for a 1965 and newer
    • Dick W.
      • 10483
      Old "Indian Trick". Drill a very small hole in the engine side of the motor, right over the shaft. A couple drops of light oil will quieten the motor down 99% of the time. Clean the oil from the outside of the motor and place a very tiny bit of epoxy to seal the hole. Clean it up, a little paint, and you are back in business.
      Dick Whittington
      • Claus S.
        • December 30, 2010
        • 414
        #18
        Thanks for the tip Dick Learning new "how to`s" every day
        I have cleaned the old fan for the blower motor and it came out okay(Should i paint it?The old and new fan is 1 centimeter longer than the new fan(the new fan is 6 centimeters long and the old is 7 centimeters long)
        The most important difference is that there is no set screw on the axle for the blower motor on the old fan
        • Gary B.
          • February 1, 1997
          • 6979
          #19
          All,
          Does anyone have a simple or clever way to check or redo the balance on the fan cage?
          Gary
          • Claus S.
            • December 30, 2010
            • 414
            #20
            When looking at the balance weights on the fan for my car i will not take them off.
            I got the fan cleaned good and if i decide to take the fan to get new coating it will be done with the weights on
            The original fan is just not longer but it is a little bigger in diameter as well
            • Claus S.
              • December 30, 2010
              • 414
              #21
              I have a couple of questions about some AC parts for my 64 coupeI am missing the bracket that is placed on the AC boxes so great if anybody can help me with the measurements on the bracket
              The length, width and the flat part on the middle of the bracket before it turns down to lay flat on the boxes on the AC boxes(see the red arrows on the picture to the left and the one to the right)
              Does one of the hoses from the drier go over the top of the radiator support or thru a hole(see the picture in the middle)
              It is hard to tell from looking at the picture if the hose is cut or if it goes thru the radiator support
              • Claus S.
                • December 30, 2010
                • 414
                #22
                How do you check if this is the original AC blower motor to the car?
                This is what is says on the blower motor: DELCO APPLIANCE 5044559 ROCHESTER N.Y. USA 12.0 V
                • Jim S.
                  • March 1, 1986
                  • 1392
                  #23
                  Claus ,
                  On the bracket . Unfortunately, I installed my set up a while back , so even though I tried , I could only get 1 measurement ; it is 7/8 tall .
                  There is no real flat portion per say as it does not have a hard bend , but rather curves into position. . Add the lips on the top and the bottom and the angle cuts at each end , and you have a real nightmare of a part to duplicate .
                  As for your fan , it sure looks correct . It should also have a date stamped into it , which will further help you determine if it is thee correct one .
                  Jim
                  • Wayne M.
                    • March 1, 1980
                    • 6414
                    #24
                    Claus -- yes, that's the same as on my early '65 air car. The date was yellow ink-stamped (messy) 8 - 64 near the center bearing location.
                    c
                    • Claus S.
                      • December 30, 2010
                      • 414
                      #25
                      Thanks Jim and Wayne I will have a look to see if i can find any ink stamp on the blower motor tomorrow
                      Jim. Thanks for the measurements I found some good pictures of the bracket so i have already made it but there is some marks on the bracket after some tools i used so i will make a new one
                      • Jim S.
                        • March 1, 1986
                        • 1392
                        #26
                        Here is a picture of mine to help you along .
                        Jim
                        • Claus S.
                          • December 30, 2010
                          • 414
                          #27
                          Thanks for posting the picture Jim
                          Is the bracket for the washer bag(riveted on the inner left fender)on factory AC cars supposed to be painted semi flat black or plated?
                          The date stamp on the AC blower motor just say 5(see the picture to the right)
                          Can anybody take a picture of the bracket from top looking down?(so i can see the curves/bends on the bracket)See the picture below for the angle i need a picture of the bracket.
                          If any have a picture post it here or send it to me on email: ro-schje@online.no
                          • Wayne M.
                            • March 1, 1980
                            • 6414
                            #28
                            Originally posted by Claus Roger Schjerverud (52628)
                            .....The date stamp on the AC blower motor just say 5 (see the picture to the right)
                            Can anybody take a picture of the bracket from top looking down? (so i can see the curves/bends on the bracket) See the picture below for the angle i need a picture of the bracket.
                            Claus --- tough assignment, as expansion tank and hoses prevent a clear shot. Anyway, here's 2 views, the first from below, looking up (see expansion tank circumferential weld and retaining straps). Second pic is from above, looking down.
                            Interesting that your '64 blower motor also uses yellow ink stamp (ie. no stamping with metal die, like the delco part #). Is your car a late '64 ?
                            • Jim S.
                              • March 1, 1986
                              • 1392
                              #29
                              here is as good as I can get .
                              • Claus S.
                                • December 30, 2010
                                • 414
                                #30
                                Thanks Wayne and Jim for posting pictures of the bracket It sure helps me a lot
                                Here is a bracket i made the other evening but i am not going to use since i mostly made it as a template
