Re: Vacuum Advance suppliers
The VAC is worth 3 total judging points - two for originality and one for condition, and not all the JGs specify the number, and you can't always read the number with the distributor cap installed.
So it's better to have a VAC that is functionally matched to the engine, but not all OE VACs are so matched, such as the "201-15" on the '63 340 HP engine.
If I know that a VAC is a B-number replacement, I take one point for "OE replacement" regardless of whether the B-number spec is equivalent to OE, and if I know the B-number replacement is not a good match for the engine's vacuum characterisitcs, I verbally inform the owner and state which B-number is the best match.
At a recent chapter judging event we had a very original '65 L-79 with about 60K miles that had been in a warehouse for about 20 years. It has the original 236-16 VAC, but it had a lot of visible rust on the housing, so it lost the condition point.
The owner plans to replace this OE VAC with a B20 or B26, which is better matched to the vacuum characteristics of the L-79 than the B28 equivalent to the 236-16.
A properly matched VAC is critical to proper engine operation, so IMO it's more important to have a properly functioning and properly matched VAC even if one (out of 4500) judging point has to be sacrificed to do so.
But it works perfectly and is made in the USA! Shocking.
