I have a problem with the horn in a 1973 coupe. I replaced the original steering column and replaced it with a tilt and telescoping steering column that I bought new. I had the local Chevy dealer do the work. This was done in March of 2011. Every thing was working fine....then the horn did not work. This began in September 2012. The horn button will depress but no horn. I noticed with the hood up that when I pushed the horn button the horn relay would click. To make sure that the horn was working I ran a wire from the positive terminal of the battery to the positive plug for the horn and it worked. I replaced the relay and the horn worked, for one month. The horn relay is clicking again! I don't know if there is a wire in the column that has had the insulation scraped off. I looked at the fuse box and none of the fuses are blown. I do not know how to trouble shoot for the wire. Any ideas.
Kim
Kim
