1979 A/C clutch toggles off and on is that normal? - NCRS Discussion Boards
  • Gary V.
    • April 15, 2012
    • 76
    The A/C clutch toggles off and on, the A/C blows cold. I'm not sure if that is a sign of low freon or not. With this year 1979 should the compressor always be on when the A/C setting is on Max or Normal cool?
    • 6940
    Re: 1979 A/C clutch toggles off and on is that normal?
    Gary generally that a sign of low freon. It is normal for some cycling of the compressor, you should have a pressure gage installed so you can watch at what pressure the A/C clutch is cycling at. frequent cycling is low refegeriant.
    • Jim T.
      • March 1, 1993
      • 5351
      If you 1979 has a sight glass at the top of the dryer and you see lots of bubbles viewing the sight glass, this normally means the air conditioning system is low on R12. My 1970 has the sight glass equipped dryer I am not familiar with 1979.
        • 6940
        Jim, I don't believe they had a site glass on 79. its just a aluminum canister on that year.
        • Gary V.
          • April 15, 2012
          • 76
          Thanks for the replies, It does not have a site glass and the A/C clutch is not rapid cycling. I read the shop manual and I'm trying to understand what their talking about. I will try to get a gauge on there and see at what pressure the clutch disengages at.
            • 6940
            Gary, I don't know what your outside temp is, But the colder it is the more it will cycle. In general it really not a good time of the year to check the a/c operation and its performance, unless your in a warm climate like Fla.
            • Bob E.
              Infrequent User
              • March 1, 1995
              • 20
              I believe the '79 Corvette uses a CCOT, cycling clutch orifice tube, A/C system. The A/C compressor
              cycles off and on in normal operation.
              • Gary V.
                • April 15, 2012
                • 76
                Thanks Bob, It does have the CCOT system. I see the acronym in the service manual but never the explanation of the letters. I live in Florida and the A/C compressor seemed to be on all the time in summer. With a little cooler weather it's probably normal to cycle. If it ever gets to the point of rapid cycling, I'll know the freon is low.
