I had my local Chevrolet Dealer run ALL available frame/suspension part numbers for mid-years. This is what you can purchase today; front control arm bushings both upper and lowers, rear spring end mount bolts/washers/rubber washer, rubber bushings, rear control arm bushings and insert pin, AC/Delco rear shocks. Question is are these parts worth the price or just buy repo from one of our friendly vendors? Just a added note, rumor is GM may begin to delete ALL pre 1982 parts numbers shortly. Any thoughts members...
C2 Suspension Parts, GM vs Aftermarket
Re: C2 Susspension Parts, GM verses Aftermarket
I kind of doubt that your dealer ran ALL of the original C2 suspension and frame part numbers. For one thing, I highly doubt that the dealer even has any record of the original part numbers unless you supplied them. In any event, the listing you described is about right as far as what's still available. However, the upper front control arm bushings are not the original part number and are not as originally configured. The rear spring end (long) bolts have not been of the original part number or exact configuration for years and even the last ones available are available no more.
As far as the Delco shocks go, they are NOTHING like the original shocks in configuration. However, I think that under NCRS judging rules you can still get some credit for them if you leave the ugly and totally non-original Delco labels on them.
Whether to buy them from GM depends. Most of the parts you mentioned that are still available are pretty low cost even through GM. The bushings are somewhat of an exception. If you can get bushings in the reproduction or aftermarket that you KNOW are manufactured by Harris or Clevite, they'll be the same as GM. Otherwise, go with the GM.
As far as whether GM is going to discontinue whatever parts for 53-82 Corvettes are still available, I doubt there is such a policy. However, there are very few such parts still available as it is. Without a doubt, in the next several years the vast majority of those few will be gone.In Appreciation of John Hinckley- Top
I bought some lower control arm bushings from Corvette Central as part of their kit. The bushing were made from a noticeable thinner steel when compairing to original. When pressing them into the control arm the steel flange started folded around. I threw them way and bought some Raybestos (professional line) from Rock Auto and they were much closer if not exact to the originals with the exception to the part number on the rubber that is covered by the end cap.
The uppers in the kit from CC looked to be the correct thickness and installed fine.
Mike- Top
Mike
Mike-----
The 1963-72 original bushings, upper and lower, were manufactured by Harris and that name appears embossed on the exposed rubber portion of the bushing.
Beginning in 1973, the upper bushing manufacturer changed to Clevite and that name appeared on the exposed rubber. The outer steel shell was slightly lengthened on these bushings and the inner rubber collar disappeared. These bushings became SERVICE for 63-72 after 1973.In Appreciation of John Hinckley- Top
Mark------
They could still be Clevite. Most of the major automotive manufacturers have foreign manufacturing operations now. Look at the exposed rubber on either end and see if there is an embossed brand name.In Appreciation of John Hinckley- Top
I am a little confused on this subject so wanted to bring back this post from the dead…….
Hoping someone can chime in and help explain.
I Realize the configuration of upper a arm GM service replacement bushings is different than production. Explained above, the configuration offered by GM in Service DID NOT have the rubber exposed on the insides after 73…….. Were the GM production configurations ever offered in service before 73 by GM? What is confusing is I have seen reproduction bushings more closely resemble production but RARELY see "correct" GM service replacements.
Any help very much appreciated, happy holidays everyone
Rick-----
The original bushings used in PRODUCTION from 1963-72 (and also non-Corvette applications prior to 1963) were GM #3711826. These were also available in SERVICE until January, 1973. At that time, they were discontinued and replaced by GM #401267 which was also used for some non-Corvette applications prior to that time.
Why don't you see the 3711826 very often? Well, the fact that it was discontinued 41 years ago probably has a lot to do with it.In Appreciation of John Hinckley- Top
