1967 antenna fitment - NCRS Discussion Boards
  • Scott M.
    • January 1, 1996
    • 216
    I was wondering if all the '67 antenna assemblies fit this poorly. This is a photo of a repro body and nut and as you can see there is a relatively large gap around the body. This started my search for an original body and nut. Well I found those items today and the photo of these parts assembled doesn't look much better. Seeing that the nut has a retaining lip around the inside at the top, it would seem that a collar between the body and nut may have been planned. Don't other GM cars of this era use that configuration, a collar between the nut and body? I would like to see or hear about other '67 fitments because aesthetically this kind of detail drives me nuts.
  • Jack C.
    • September 30, 1992
    • 1090
    Re: 1967 antenna fitment
    My 68 is the same assembly as the 67 and there is a gap around the body similar to your photo.
    Jack Corso
    1972 Elkhart Green LT-1 Coupe 43,200 miles
    Top Flight 1994, 2018 & 2021
