Mid-year, under-car exhaust question
Re: Mid-year, under-car exhaust question
Gary, The clamp I measured quickly with a tape measure so anything is possible. My clamp is a CC clamp that came with the Hanger. I Can tell you that the clamps that Gm made may have not all measured the same leaving some wiggle room, as the era of clamps were likely used through out the GM lines, so pipe and muffler manufacters may of had pipes that varied slightly when expanding.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Gary,
That nut is used as the standard factory build for 63 - 102634, 64 - 273802, 65 - ??, 66 - 1359887, 67 - 1359887
Do you have any information (date) when the 1359887 nut started to be used?
I believe that the nut shown in the AIM is for the 2" exhaust while the 2 1/2 exhaust used a clamp with a different nut and lock washer. The small exhaust (2") does show up in 63/64 on low performance engines, "I believe" (do not know for sure)
The larger, N11 - 2 1/2 exhaust, is not listed in the AIM (based upon current understanding).- Top
Alan,Gary,
I don't know if the 1359887 flange nut started in '66, or if it started in '65. I don't have the '65 AIM to check. In the '66 AIM on UPC 8, sheet A2, only the flange nut is called out for the center clamp location, and I'm not sure if the exhaust system in the '66 AIM is the 2" or 2.5" system.
I have seen photos of an unrestored '66 and an unrestored '67 with the 2.5" pipes and they both show the flange nuts, without lock washers at the center clamp location. The story differs for the tail pipe extension clamps; they use the standard hex nut and lock washer, not the flange nut.
Gary- Top
