Dash Harness Neatness - NCRS Discussion Boards
  • Karl B.
    • March 5, 2010
    • 13
    I have several wires just hanging down from the bottom of the dash with no obvious home.
    They are: The circuit breaker (with red wires), turn signal flasher, rear body connector, and the heater control lamp.
    All of them have clips or other attaching hardware. But I don't have a clue where to re-attach them. Are their clear pictures available somewhere?
    Any help is appreciated.
    Karl
    • 6940
    Re: Dash Harness Neatness
    [QUOTE=Karl Brehm (51506);638144]I have several wires just hanging down from the bottom of the dash with no obvious home.
    Karl, I am not sure how close your 66 is to my 63, but might be the same.
    The circut breaker attachs to clip attached to the bird cage above the drivers kick panel.
    believe your flasher bracket attaches to the radio side panel with the rear most screw and the flasher clips into it.
    The rear body connector attachs to the bird cage area directly above the headlamp switch.
    Not sure about the heater control lamp.There maybe a socket above the radio.
    If you have a AIM it should detail everything.
      Karl
      Karl -
      The "torpedo lamp" for the heater control bezels fits in a slot at 6 o'clock in the bottom of the clock bracket; the other two slots at 4 and 8 are only used on A/C cars.
