Okay I searched the threads and still have some questions.
1. When you either remove or install the transmission will there be enough room to turn the trans and remove without damage to the insulation blanket in the transmission tunnel? Any suggestions on how to protect the insulation?
2. I have also read that it makes sense to remove the bell housing with the transmission. Does this mean to remove 4 bolts attaching the trans to the bell housing and the bell housing bolts or leave the trans attached to the bell housing to remove as an assembly?
3. I read that you can use a transmission jack. How is that possible with a fixed crossmember?
4. Based on all OEM parts existing should I still check run out on bell housing and flywheel and just replace clutch and bearing then reassemble?
I will be performing all work laying under the car with it on jack stands. I am going to rebuild shifter, replace side cover gasket, and shift lever shaft bushings while transmission is out. I may clean and detail under body and frame while there too.
5. Any other things I should consider while transmission is out?
I have only ever pulled a 4 spd. trans on my 68 GTO and it was a can of corn without the cross member in the way. That was many years ago when GM parts were still available for clutch replacement.
Bill
Bill
