72 LT1 manifold color - NCRS Discussion Boards
  • Rick M.
    • June 30, 1995
    • 74
    I see most LT1 intakes are silver and the judging manual says a dull aluminun color. Can someone tell me which is correct? Thanks
    • 15573
    Re: 72 LT1 manifold color
    I guess we are talking about definitions. To my way of thinking dull aluminum is silver, but not everyone sees it that way. Maybe a dull or flat silver would be more descriptive. It is not like a BC/CC auto body silver.
    Any chance someone has an original un-molested 1972 LT1 near you?
    • Rick M.
      • June 30, 1995
      • 74
      I don't know of one. I have a can of paint that says it is aluminum color and when I tested it it is dull I hate to paint it with the wrong color. Does anyone have any pictures of one. Thank you
        • 15573
        Pretty sure I do from home tonight, but it is a 1970. You may be better off with a picture of a 1972, but if none appears by tonight I will see what I have.
        • Patrick B.
          • August 31, 1985
          • 1986
          Is the paint/color unique to a 72 LT-1? I took a 70 LT-1 manifold off 30 years ago and can take pictures of it if that is of any help.
            • 15573
            I believe there in no difference in the paint color between the three years of LT1, but I have meet a couple of people who swear there is no paint on 1972 LT1 intake manifolds. Now that would be a difference.
            • Rick M.
              • June 30, 1995
              • 74
              In the judging manual says 350 Aluminums were painted a dull aluminun paint and 454 were natural
              • Patrick B.
                • August 31, 1985
                • 1986
                If memory serves me right, I believe there was little if any paint on the 70 manifold except maybe near the heads. I will get it out this week and take a picture.
                • Rick M.
                  • June 30, 1995
                  • 74
                  I know there was some orange over spray(front and back) on the manifold.
                    • 15573
                    For 1970 the quantity and location of silver/orange paint depends on the production date of the engine. Not worth getting into here because the topic is about 1972. However, I am pretty sure we covered that issue in the 1970-72 TIM&JG.
                    • Kevin G.
                      • February 1, 2005
                      • 1074
                      Hope these help.
                      • Larry M.
                        • January 1, 1992
                        • 2688
                        ASSUMING that you are planning to have your car judged (and this is a big assumption on my part) would you do better to have the manifold "reskinned". There are a couple of folks that do this with excellent results. Cost is moderate ($$$)
                        This is what many of the C2 guys do?? Or is the LT1 manifold somehow different in its finish than the aluminum manifolds of the C2 cars?? I don't remember any big differences during this time period.
                        Larry
                          • 15573
                          Larry
                          The LT1 manifold was painted with aluminum paint. If you want to cover all that expensive re-skinning with paint -- knock your socks off.
                            • 15573
                            Nice pictures Kevin -- thanks. The LP in the second image is likely the identifying stamp of the UAW worker who hot tested, balanced and set the timing at the hot test station in Flint. I was told that each worker at this station had an identifying mark on a hammer and after they performed the above tests and adjustments the marked the engine so that if there were future issues the worker responsible could be identified. Among the marks I have seen initials are unusual. More often there is a symbol of some kind, and the location is all over the intake.
                              • 15573
                              Some pictures:
                              1972:
                              Interesting to note that Kevin's 1972 as well as this above shows no silver paint on the attaching bolts, and that argues for no paint in 1972.
                              1970 #2161:
                              Note in the photo below the silver paint on the distributor hold-down and fastener. Early 1970 LT1 intakes were brush painted silver and the rear of the engine was brush painted orange. I don't know how long that brush painting continued, but I have seen LT1s in February 1970 with sprayed silver and orange. So these techniques will not apply to your 1972, however the color should be the same -- I think.
                              1970 Z28 1100 miles -- before you turn up your nose remember these engines, and a lot others, were produced on the same assembly line, with the same tools and techniques, by the same workers, at the same time. Of course I have a lot of 1970 images -- that is my interest.
