Restoring my 67 vinyl covered hardtop. I've never had it on the car since I purchased it in 86. The vinyl is perfect but weatherstip, stainless, rear window, and headliner need restoration/replacement. The main reason for never installing it on the car is that sometime during its life both LH and RH verticle side brackets towards the rear were broken off. The top must have been put down on the tabs resulting in a fracture of the weld. I've purchased repro brackets that require they be welded on. I've removed everything off the top and have purchased a complete restoration kit from The Hardtop Shop. I have a skilled welder that believes he can tack weld the brackets back on without affecting the vinyl covering. My challenge is properly locating the brackets for him. I was wondering if someone could provide me some locating dimensions off a common feature(s) that would allow me to properly locate the brackets? This weekend I planned on duct taping the brackets on the top in the approximate location then carefully installing the top on the car and positioning the brackets properly once installed. I could then scribe some lines for the weld location.
thanks
Dereck
thanks
Dereck
). Also, the upper stainless sticks out a little along sides but is flush to the hardtop surface along the top, I found.
