I have run across some NOS tail light lenses. There are side markers too. These lenses have a "1971" date on them. I know that lenses have earlier date for production cars.
My real question is: Did they put the extra production run of parts to be used as over the counter parts? Or, did they use the extra parts for the following years cars until they ran out and the next years dated parts showed up? My guess would be they used what they had and just kept going until the parts with the following years dated showed up. I dought they even knew when the date change over happened.
The lenses are the same for 68-72 and maybe even a little later (68-no back-up lens) Is it just luck that these are "71", or is it just luck of the draw on what you got when you purchased an over the counter set.
These were purchased from GM in 1978.
