Tach Cable - NCRS Discussion Boards
Tach Cable
  • Bob W.
    • August 31, 1981
    • 84
    Tach Cable
    Do both the speedometer cable and tach cable go through the same hole in the dash support behind the cluster. If so is there a trick to getting them both through? I have had one connected, both unconnected and can't get both through.
  • Don H.
    • December 1, 1981
    • 1482
    Re: Tach Cable
    Bob, You did not mention what HP your car is but neither (high or low HP) tach cable go through the same hole as the speedometer. The high HP Fuel Injection tach is driven from the distributor and the low HP engines tach are driven by the generator. Both are routed through different holes and neither are the speedometer cable hole. Good luck, Don H.
    • Bob W.
      • August 31, 1981
      • 84
      Re: Tach Cable
      This is just the base 230 hp car
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        Re: Tach Cable
        There should be 2 holes in the dash. This is a '59. AIM calls out 2 rubber grommets also...... IIRC.
        • Bob W.
          • August 31, 1981
          • 84
          Re: Tach Cable
          You would think there would be two but only one
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11302
            Re: Tach Cable
            Bob, Very strange only one hole. Was the nose replaced on the car?
            Either way, I'd just open up the single hole with a keyhole saw to allow the 2 cables to fit through.
            Rich
