GREETINGS,
Does someone no if the Deep Groove Pulley used on the Big Block smog pumps, was this also used on the 327 Special Hi-Performance Engines with Deep Groove Pulleys on the water pump , crankshaft and alternator ??? This engine used alot of hi-performance parts just as the Big Block engines did. This is a 1968 HT engine code. Thanks in advance.
