Are 63 seats same as 64? - NCRS Discussion Boards
  • Russ S.
    • April 30, 1982
    • 2161
    Are 63 seats and tracks the same as 64 or are they unique to 63? Thanks
    P.S. I should add that I am referring to the frames and tracks not the seat covers.
  • Paul Y.
    • September 30, 1982
    • 570
    Re: Are 63 seats same as 64?
    63 seats are different than 64-7 seats. the 63 seats slide in a loop on each side in the back with a bolt on each side in the front. They also differ on the top where they come to more of a sharp edge vs the more rounded top of the 64 seat. The foam can inter change if you carve some off on the top where it slants from front to back of the seat top
    It's a good life!
    • Russ S.
      • April 30, 1982
      • 2161
      Paul, 64 -66 and maybe 67 also slide into the loop at the rear of the seat tracks.
      • Joe R.
        • July 31, 1976
        • 4547
        Russ,
        The 63 seat can be distinguished from the 64-67 because it can be adjusted. There are plates at each mounting point to adjust the seat up and down. That does not exist on the 64-67 seat. There are several differences including the handle on the 63 is a large chromed curved rod and the 64 is a pot metal chromed handle.
        You cannot mistake a 63 for any other seat in the C-2 series.
        JR
        • Gary H.
          • June 8, 2008
          • 308
          Here are some pics of the original seats in my 63. You can see the height adjustments on the rail, sharp top corner and chrome adjustment lever.
          Gary
          • Russ S.
            • April 30, 1982
            • 2161
            Thanks gentlemen for the help. RS
