frame paint 59 vette - NCRS Discussion Boards
  • Patrick M.
    • July 20, 2012
    • 50
    I am about to paint the frame on my 59 vette. First of all there are no stenciled letters or numbers. The judging book says it is painted a dull gloss black. Is a dull gloss satin or just a gloss? Thanks Pat McPherson55168
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: frame paint 59 vette
    Interesting JG description "dull gloss black".
    Is it dull or gloss???
    • Mike E.
      • June 24, 2012
      • 920
      On my Mid-Year frame I used this Eastwood 2K Ceramic Satin Chassis Black. It might be a bit too shiney. I'm hoping it will age a little duller. It's really tough stuff, you can't scratch it off with a nail. Under it I used their 1:1 Epoxy Primer.
      Primed
      Mike
      • Tracy C.
        • July 31, 2003
        • 2739
        Looks good to me Mike. If you completely assemble your chassis in that position (upside down), you will find it much easier. That is how the factory did too.
        • Dan H.
          • July 31, 1977
          • 1365
          I used to paint my restored frames with Dupont chassis paint. Was a tar based paint with a slight brownish hue to it. Was very glossy when first applied, mellowed out after a year or so but still a nice gloss to it. Don't get any gasoline etc on it, comes off easy.
          1964 Red FI Coupe, DUNTOV '09
          • Mike E.
            • June 24, 2012
            • 920
            Yup, That's what I was planing on doing. I have most of the parts for the front ready to start reassemby now.
            Quanta still makes such a paint. And it's cheap...I noticed this shot below of a mid-year frame from Johh H's PowerPoint you can see it looked pretty bad before it left the plant. If you want 100% correct that's good solution. I actually considered using it over what I put on. That way if it wore off it would still have the tough stuff under it.
            Mike
