No power at the fuse box for the heater blower motor - NCRS Discussion Boards
  • Richard R.
    • November 17, 2009
    • 76
    I have no power to the blower switch. Went to the fuse block, fuse is good but no power across the terminals. What should I do at this point?
    • 6940
    Re: No power at the fuse box for the heater blower motor
    Richard, under the hood is the horn relay(drivers side inner fender well) and the should be a fuse in a in line fuse (white plastic case 25amp fuse size, red wire on one side, orange wire coming out). thats the power soure for the blower relay. I don't believe the swictch was powered, those wires are the ground side of the circuts which feed the ground through the resister to cut the speeds down.
    • Richard R.
      • November 17, 2009
      • 76
      Ed
      Does that mean the fuse block heater slot gets its power from the inline fuse?
        • 6940
        Rich, is your car a A/C car?
        • Richard R.
          • November 17, 2009
          • 76
          It's a non air car.
            • 6940
            Rich I looked at the wiring dia. in the shop manuel it looks like the ing. switch feeds 12 volts to the orange wire on back side of fuse block and the brown wire to blower switch is powered through fuse. you may want to remove the fuse block and look at wire colors. I have a A/C car and there is a inline fuse under hood to power blower relay.
            • Richard R.
              • November 17, 2009
              • 76
              Thanks so much Ed, that is the link I could not find. I will get into it tomorrow.
              • Richard R.
                • November 17, 2009
                • 76
                Ed
                I found the problem at the steering colum connection, wire pulled out of the connector. Without your tip I would have never found it! Thanks again!
