57/61 duel four intake - NCRS Discussion Boards
  • Wally A.
    • May 31, 1979
    • 170
    anyone reproducing the heat shield/oil deflector for bottom side of the duel four intake?
  • Mark P.
    • July 31, 2003
    • 407
    Re: 57/61 duel four intake
    I have a couple funtional replacements if you are interested.
    Mark
    • Bruce B.
      • May 31, 1996
      • 2930
      Wally,
      If you can find an old cast iron manifold chances are the heat shield will fit the 2 X 4 aluminum intake,
      • Wally A.
        • May 31, 1979
        • 170
        thanks for the input, will be looking for an iron intake. wally
        • Clem Z.
          • January 1, 2006
          • 9427
          if you run with blocked heat riser you do not need this shield as there will be no heat to "coke" the oil vapors
