C1 (1960) need fan blade mounting bolts - NCRS Discussion Boards
  • Philip P.
    • February 28, 2011
    • 558
    Re: C1 (1960) need fan blade mounting bolts
    Don, Joe
    The spacer is 1 7/8 inches, I can not remember how much of the bolt that was sticking out past the water pump hub but, when you add the spacer, pulley. pulley reenforcement plate and the lock washers I would think about 1/8 inch is sticking out past the hub. the spacer could be 1 15/16 but I could not read it that close.
    Phil
