Hello, I'm currently restoring a 66 tanker and I would greatly appreciate any photos fellow NCRS members may have of the factory "grind" in the rear fenderwells/wheelwell openings. The NCRS Technical Information Manual touches on the subject, however, it's somewhat unclear to me. Thank you in advance for any assistance you may provide....I sincerley want this to be historically accurate! Scott
1963-1966 Tanker
Re: 1963-1966 Tanker
Scott -- can you quote exactly how the 1966 Tech Manual describes the grind ? I notice on your post on the "other" forum that you mention a dimension of 8". Is this the overall length of the grind, or the starting point or the middle ?
I have only the '65 TIM&JG and all it says is: "On both sides, the forward lip of the rear quarter panels have the lip partially ground (shaved) off".
The pic below is of (I believe) an original '66, with one re-paint. Owned by a member in Canada, and delivered originally to a Canadian dealer.
As you can see, the cut is quite crude; the intention is (quote from Aug '64 Chev Service News) "to provide adequate wheel travel clearance for 7.10 to 7.60 tires mounted on P48 Aluminum Knock-off wheels (6" rim width) .... by cutting material away in the wheel openings" (end quote). For the life of me, I cannot see how this factory lip grinding would accomplish anything of the sort.Attached Files- Top
very true but if you lower the car for better high speed handling you will need to grind off the lip or the fronts will grab the fender lip and crack the fender. don't ask how i know that.
you have to remember back in the day most people who bought corvettes used them for what they were performance cars. i had a bud who took a saber saw to the rear fenders of a new corvette so he could install slicks. i ran my on frozen lake race course,on dirt tracks and raced every sunday either at the drag strip or a road course or a auto cross and you needed more rubber on the ground so the fenders got in the way.
- Top
Nothing done to front fender openings; at least not according to Chev documentation ('65 AIM [UPC N03]), nor the Chevrolet News mod's for big tank (view C, below.)
m- Top
