What Happened To My Clock? - NCRS Discussion Boards
  • Daniel K.
    • April 1, 2002
    • 190
    Took the '63 out for a drive yesterday. About 20 minutes into the drive, the clock went nuts. Remember when playing cards were attached to your bike to make the engine noise? This is exactly what the clock sounded like. Went on for about 10 minutes (on my return to home base) then it stopped only to see the clock face fog up (with smoke?). I'm sure there are many wonderful restoration folks to send the clock to, but I'm more interested in finding out what happened. Any ideas?
    Thanks in advance and Happy Holidays.
    Dan K.
  • Scott S.
    • March 1, 1979
    • 747
    Re: What Happened To My Clock?
    Points inside most likely fused together. YOU SHOULD DISCONNECT the battery cable!
    Scott
    • Daniel K.
      • April 1, 2002
      • 190
      Yes, have battery disconnect.
      Thanks.
      • Dennis B.
        • May 31, 2004
        • 174
        My "tick-tock" clock failed sometime before I bought my '66 coupe (1972). Last winter I decided to restore my cluster and clock and proceeded to pull both units out of the car. When I got to the clock I found the plug was totally melted. The attached wiring was melted right back into the wiring harness. I peeled the harness back a bit and it got no better. Ordered a new dash harness and while the cluster and clock were out being restored I installed the new harness.
        Dennis
        • Joe R.
          • July 31, 1976
          • 4547
          That machine gun sound was the clock trying to reset itself and the points contacted time after time without moving. Burned the coil out of the clock.
          Nothing serious. Any clock rebuilder will fix you right up!
          Probably happen again in another 49 years! Hang around and see!
          JR
            All-----
            Converting to a quartz movement gets around all these sort of problems. I suppose if one is considering a PV then one has to stay with a "tic-toc" movement but otherwise the quartz is the only way to go. Period.
            • Gerald L.
              • August 31, 1989
              • 80
              We each have our own start up traditions, whether they really are beneficial or not. Before I reconnect the battery cutoff switch I tap a small screw driver blade to the terminals and wait a moment and check to see that the 'tic-toc' clock is running. My hope is that the points will last longer than 49 years if the + clock terminal is charged with the points away. Like I said, just a tradition!
              • Don H.
                • December 1, 1981
                • 1482
                Joe, It is not just for a PV when a quartz conversion is a problem. It should be caught doing ops for flight judging. Don H.
                  Don-----
                  Yes, but in that case I don't think it results in automatic failure, just a minor point deduction.
                  • Don H.
                    Moderator
                    • June 16, 2009
                    • 2236
                    Hi Joe,
                    total deduct for clock with quartz conversion. Ask me how I know. It's right in the TIM&JG.
                    Don
                    • Dick W.
                      • 10483
                      Originally posted by Don Hooper (50543)
                      Hi Joe,
                      Don
                      And I think you would have trouble fixing it in 15 minutes while on a PV. When I was a team leader, more than one car failed PV because of a quartz clock
                      Dick Whittington
                      • Mike E.
                        • June 24, 2012
                        • 920
                        Dennis
                        Wow that should have blown the fuse. I would double check all the fuses in the new harness to make sure it's not over fused.
                        It's not that hard to change a C2 clock. Folks might consider a quartz movement driving and mechanical one for judging.
                        Mike
                        • Dennis B.
                          • May 31, 2004
                          • 174
                          Mike
                          Mike,
                          I also thought the fuse would have gone before such heat could build up. Nonetheless that's what I found. A new harness and fuse block are in place now with the recommended fuses. My clock was restored as a "tic-toc". I do have a blade type battery disconnect installed and whenever the car is not in use or I'm not around it the electrical system is disabled. That doesn't do much for keeping the correct time on the clock however.
                          Dennis
                          • Dick W.
                            • 10483
                            Frequent poster here, Joe Ray, can take care of your clock needs. Does an excellent job of restoration/repair.
                            Dick Whittington
                            • Mike E.
                              • June 24, 2012
                              • 920
                              Mike,
                              Dennis
                              That's the ticket!! If my memory serves me correct there was some type of mechancal system on some automotive clocks that would make the clock run faster or slower based on adjusting the time forward or back in an attempt to make the clock more acurate.
                              I'm not sure that feature was in a C2 clock or perhaps I dreamed the whole thing up.
                              Mike
