75 - 76 Distributor Top Shield - NCRS Discussion Boards
  • Alger R.
    • September 30, 1999
    • 279
    I have two different Distributor Top Shields that are for 75 - 76. The two are identical except that one has a square hole in the front surface and a vertical bulge in the back surface. The other shield has no hole and no bulge. Everything else is identical The one with the hole and bulge still has a GM part number tag 351696. Was there a design change somewhere in 75 or 76? Which one is correct for my April 75 car? I couldn't find anything in the archives.
    AL
    75 Convertible
    L48 M20
    Bright Green / Saddle
  • Alger R.
    • 279
    Re: 75 - 76 Distributor Top Shield
    Attached are pics of the two types of shields that are in question. Can anyone ID these as to years each was used? used (most likely 75 - 77E )667-1.jpg667-2.jpg1060-1.jpg1060-2.jpg
    One version has the square hole and the vertical bulge on back. the other has no hole or bulge?
    AL
    75 Convertible
    L48 M20
    • Peter S.
      • March 28, 2012
      • 327
      Hi Alger,
      I can confirm that the shield on the left matches my original '75s shielding - square hole front, vertical bulge in back.
      • Alan D.
        • August 31, 2000
        • 111
        The one on the left matches my 1977 also. It is the original part and the car has been topflighted at all levels.
