Re: FI modified as a tunnel ram on flea. Never saw one like this.
Jerry, The dual air meter thumbtack style spill valve modification purpose is your question I believe.
I have wondered about this for an eon now. The valve used the stock nail but a smaller thumbtack. Smaller in OD. A restrictor was pressed into the bottom section of the spill valve body. The thumbtack now rested on this restrictor.
When the vacuum drops the thumbtack rests on the seat and you get full fuel flow. With the restrictor in place the flow of the fuel was restricted.
Problem with the old FIs is they actually need more air and less fuel. So the dual air meter accomplishes this in a rather crude fashion though.
So with all these increased air flow the spill valve hole must be too big and hence the need for this modified spill valve.
The first time I ever saw one of these spill valves was when I got a ton of the Grady Davis mechanical parts from a Gulf Research car. I remember looking at the weird spill valve and didn't have a clue what I was looking at. One of my pals here got that spill valve.
Seems that lately the dual meter craze has hit here. Yes they are neat to look at but do they actually work like a charm????
Take a stock 63 to 65 cone (also a 62 cone) and have it bored out so that the back edge of it is paper thin-or a tad thicker.
Not that difficult although I don't get involved with modifications.
The drawing I had/have around here was drawn by John Eyestone. John was into dual air meter units.
At the NCRS National in Warren, MI in the old days John had a Gulf Research dual air unit for sale for $3750.00 That was a lot of bucks in 1990 or so and I t hink he had a hard time selling it.
At the NCRS National at Seven Springs there was a Gulf dual air meter FI unit and maybe the engine (I forget) on display next to Rich Mason's Gulf car.
Gulf research must have made a lot of those setups. None of them set the world on fire in the old days. JD
