I know this has been discussed before; but maybe this is a little different.
Question: What is proper way to crank a engine w/o starting it. Is it different
from a T/I like a L72 vs. conventional like L68(with points)?
Do you simply unhook the spark plug wire from the distributor to the coil and
just let it hang in the air w/o touching anything or should it be it be grounded?
Also I assume you unhook it from the coil side vs. distributor side or does it
make a difference? Thanks in advance. Larry
