'61 Dash Mount Bolts Do not Line up - NCRS Discussion Boards
  • Larry B.
    • October 21, 2010
    • 254
    I pulled the dash out of my '61 FI to freshen up the gauges and cluster. There was only one of the five bolts (far passenger side bolt) holding the cluster to the dash. I figured the last person to put the dash was too lazy to put the other bolts in.
    When I put the dash back in, I could only line up the one bolt described above. The other holes were not even close. I am not sure the dash is original to the car. Did they use different dashes for different years and models or could the problem be elsewhere? Cheers!
  • Mike E.
    • February 28, 1975
    • 5134
    Re: '61 Dash Mount Bolts Do not Line up
    I'll bet anything your dash pad has been replaced. Not enough appropriate shaving of the foam has been done.
