68 bb - NCRS Discussion Boards
68 bb
  • Dale C.
    • November 1, 1999
    • 844
    68 bb
    Would you recommend this car to a friend? http://www.mcecars.com/viewInventory.cfm?invID=401 The thing that got my attention was the broach marks. Do they look OK? They look rather deep and continuious, is that OK????? Car looks nice and correct with build sheet. Any thing else comes to mind looking at this car? Hope pictures come though on site listing above.
    Dale
    • 11608
    Re: 68 bb
    No.
    Yes.
    They look rather deep and continuous, is that OK????? Car looks nice and correct with build sheet. Any thing else comes to mind looking at this car? Hope pictures come though on site listing above.
    Dale
    It's several thousand dollars overpriced.
    Nice red paint but lacking in details. Way too much black spray paint hiding things.
    There are better cars for the money.
    That's my short answer.
    • Mike M.
      • May 31, 1974
      • 8365
      Re: 68 bb
      i dislike the broach marks.mike
        Re: 68 bb
        Dale
        Dale------
        It's got 1969 grilles and one slightly droopy headlight. This might indicate some previous front end damage and repair.
        The AIR system has been removed
        The master cylinder looks to be a replacement, non-GM piece.
        The tank sticker looks a little suspicious to me. I just don't see a reason for the "rust stains" as they appear.
        The engine stamp pad broach marks look too "prominent" to me. To me, they look rough enough that the head gaskets might not seal properly (the stamp pad is just an extension of the block deck surface).
        • Ronald L.
          • October 18, 2009
          • 3248
          Re: 68 bb
          Joe, fiberglass rusts you know that right? More like artificial acid aging.
          On the VIN, I'd like to see the one-piece punch holder that punched some of the letters in at a 20 degree angle and others were a direct hit.
          The 'rusting' real or accelerated on the pad is also a little odd, some areas it looks like the broach lines go over that area, mostly noted where the VIN is and that stamp has metal deformation that is not clear in the Tonawanda stamp, could it have been a partial swipe to put a new VIN on the pad, but leave the Engine date?
            • 11608
            Re: 68 bb
            I noticed that each of the broach marks is parallel, which is quite unusual for a replacement stamping if that's what it is. In addition, I do see displaced metal from both stamps though it is more prominent at the VIN than at the engine stamping.
            What would be interesting is to measure the total length of the stampings - the VIN stamping looks, if anything, like the characters are a bit too far apart.
            In the end I found many more things obviously wrong than the broach marks, and that's why I'd turn down the car.
            • Dale C.
              • November 1, 1999
              • 844
              Re: 68 bb
              Thanks to all, great insight.
              Dale
              • Paul J.
                • September 9, 2008
                • 2091
                Re: 68 bb
                Exactly. In addition, the overall condition is average, especially the interior.
                Paul
                • Dick W.
                  • 10483
                  Re: 68 bb
                  Run Forrest, run Everyone has missed the fact that it was originally a yellow car trim code 984, even shows on the tank sticker
                  Dick Whittington
                    • 11608
                    Re: 68 bb
                    I saw the yellow overspray on the wells behind the seats.
                    No one wants a yellow car anyway, right?
                    • Dick W.
                      • 10483
                      Re: 68 bb
                      Sorta like a Kermit car? The yellow used in 1968 was a pleasing color to me. Not too bright or gaudy unlike a couple of the later school buses disguised as a Corvette
                      Dick Whittington
                        • 11608
                        Re: 68 bb
                        Hey, my car resembles that remark.
                        • Ronald L.
                          • October 18, 2009
                          • 3248
                          Re: 68 bb
                          On the topic of broach marks, yes too straight for the rookie stamp shop where the hand motion gets a little loop in the lines usually seen better with the head removed. However, I bet there are some experts out there that have that all figured out, hey they might even be here reading this thread.
                            • 11608
                            Re: 68 bb
                            I don't doubt that at all.
                            However, would you pay the big dollar to have the motor restamped this well and then screw up the rest of the "restoration" in so many ways?
                            It doesn't make sense to me.
                            A "Fonawanda" stamp or an 80 grit sandpaper pad would fit this car perfectly.
                            • Ronald L.
                              • October 18, 2009
                              • 3248
                              Re: 68 bb
                              The sources I know of only get $300 to do it like this one. pocket change with respect to the total cost of the motor and other like paint. That paint job had to be more than 3k, at least 1k in paint alone, it cost 300 to paint a hood between primer, reducers, catalysts, and 1k color and there wasn't a drop of paint left over.
