In the interests of deciding which road I will take when I buy my car (serious flight judging vs. a really nice second flight, but performance modified driver) I was wondering if any members here had used the services of any of the companies out there like Gessler (or done the work themselves) that internally modify exhaust manifolds (extrude honing and/or grinding) and then flow bench test them ?
Headers are one thing and I have nothing against them, but would maintaining the OEM appearance, with a set of properly modified BB manifolds, have similar flow qualities to a good set of headers, or be close enough that the HP variable was not enough to worry about, as I don't plan to be doing heads up racing on "Pinks" so an extra .20 of a second does not matter. Believing the advertising from companies that do this service is one thing, so I am naturally skeptical of course. Reading in Pete's L88 book that TRACO added 100+ HP to an L88 with machine work and headers, has me curious as to what difference a nicely hogged out set of OEM BB manifolds would have brought on a lesser engine that received the same treatment.
I am talking about a scenario where perhaps the original 454 in a top flight C3 becomes a 496 (or the 427 in a second flight C2 becomes a 499 using a Dart/Brodix block) and in the process the carb, heads, manifolds, and any other internals, etc, are optimized for a slightly different camshaft, yet the original parts and appearance is maintained to the degree that it can be, the aforementioned NOM block option excluded of course. For the sake of the question, it would be a 9-1 comp engine that spins out to <6000 RPM.
TIA for the feedback.
. Ah, the good old days!
