Re: 66 SB hard to start when sitting for a month or so...any ideas why
if the choke plate does not close tight causing the only air getting into the engine while cranking is thru the float bowl vent causing it to push fuel from the float bowl into booster nozzles and into the engine for start up. i found this out when starting race cars with no choke plate you had to cover the whole top of the choke housing to get the engine to start
