This question is for those with years of experience and have "seen it all" at some point in time. Being a rookie owner and restorer I can not understand why someone would drill three 3/8" holes spaced across the rt. dash support with the center hole drilled dead center through the trim tag as the pics show. I realize the damage is done as far as the trim tag goes but should these holes be filled or left alone. This is a frame off, detailed resto but not a high end collectable car. It will be a driver. Thanks to all for your input and suggestions.
Dr. George
If you do that please let me know a bit before the event so I can make the proper arrangements.
