54 heater shut off - NCRS Discussion Boards
54 heater shut off
  • Brad H.
    • August 12, 2007
    • 724
    54 heater shut off
    Does the shutoff have an O ring on the end of the turn screw inside the casing? Also how do you get the screw shaft out of the casing with the packing around it, can you still get the packing or whatever this piece is, get it in and out without a problem. If I close mine I can still blow air or water through it, off the car. Thank's, Brad.
  • Cathy S.
    • August 31, 2003
    • 293
    Re: 54 heater shut off
    Im curious also. Mine leaks when open.
    • Troy P.
      • February 1, 1989
      • 1279
      I have disassembled several of these but it was years ago. So I'm a little foggy on the details.
      I was able to get the shaft and rubber tip out. Warm the rubber up first to get it soft. I don't recall any O ring or other means of sealing. I do think that when you open it you need to open it all the way tightly to get it to seal.
      I have a few extras, including a NOS one in a Buick box!
      • John S.
        • July 29, 2009
        • 640
        to pull stem out open valve and then unscrew the packing nut. a good pull should get the stem assembly out, but it probably better to warm the packing as troy has stated. when the valve is closed it is a brass on brass seal. if you can feel air on the other side when the valve is closed the problem is either the valve seat is worn or the mating surface on the stem is worn. on ebay they sell valves for the 54 where the stem is at 45 degrees rather than inline like the original. the stem assembly will work in the original valve. if you have a packing leak you can use the stem assembly from the valves on ebay or remove the old packing from the original valve stem and use graphite rope packing. rope packing can be found at plumbing supply shops or ace hardware.
        • Brad H.
          • August 12, 2007
          • 724
          Thank's guy's for the info. Brad.
          • Chris S.
            • January 1, 2000
            • 1064
            you can replace the packing with an oring - if you open it all the way - it shouldnt leak.....
            1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
            Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
            1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
            1957 Corvette - FI 3 sp - Black and Silver
            • Brad H.
              • August 12, 2007
              • 724
              Chris, Hi,what type of O ring may I ask? thought about hooking shutoff up to a garden hose with water outlet plugged to see if it leaks now in all the way open position before trying to fix something that isn't leaking. Thank"s, Brad.
