After much searching on the intertubes, I found another source for the elusive B28 Vacuum Advance Canister. I'm posting this mainly for documentation purposes in case someone needs one of these. I found it as an Airtex 4V1053 and it can be found everywhere on the web. Just Google Airtex 4V1053 Here's a couple links. http://www.amazon.com/Airtex-Distrib.../dp/B000C1ES7I http://www.rockauto.com/dbphp/x,cata...EX_4V1053.html Alternate Part Numbers: NAPA/Echlin VC-1810 Niehoff DR-305 Borg-Warner V329 BWD V329 Standard Motor Products VC-177 Standard Motor Products Hygrade VC177 AC/Delco part number D1312C GM part number is 88924985 Wells DV1810 Specs: B28 High Perf. 3-5 8 @ 5.75-8 I was skeptical when I ordered it that it would not be a real B28, but when it arrive it is indeed a B28 with the correct stamp. It even tests out pretty close to spec. I also purchased a BWD B26 and the two look identical, so I would guess they are both made by Standard Motor Products.
