Sitting on top of the interior AC/Heater box is the Vacuum Control Valve. On one side is the vacuum from the carb. When the Vacuum switch is activated (the plunger is released) it terminates the vacuum to the hot water shut off valve and allows hot water into the heater core.
I know this sounds back-wards but the system is designed so that water never flows into the heater core unless you want heat.
I believe my hot water shut off valve is bad because it never closes, with an IR gun it is equally hot on both sides.
I'm trying to determine if my vacuum control valve is good or bad so here is the question. When the plunger is released should I be able to suck any air through the valve? (carb. hose side). I seem to be able to suck air through whether the plunger is in or out.
Thoughts/comments please.............Thanks
