1954 -- need diameter of screw head in door opening - NCRS Discussion Boards
  • Peter R.
    • June 19, 2011
    • 233
    Can someone measure the head diameter of the clutch head screws at the top rear of the door opening, as shown in the attached photo? The photo is from the "entombed Corvette." The holes in my car's body are empty--the screws are long missing. I'm trying to get replacement screws from Richard Fortier. He has 1/4"-20 x 3/4" clutch pan heads with 1/2" diameter heads that should work, but I'm trying to determine if they are correct. If it's possible to measure the diameter of the screw shank, that would be a big help, too, but not absolutely necessary. Thanks for the help.
    Pete
    Pete
    1954 Corvette #814
    1957 Corvette #646 -- FI, 3-speed
  • Tim E.
    • April 1, 1993
    • 360
    Re: 1954 -- need diameter of screw head in door opening
    Pete - Just removed one for measurement. The clutch head bolt is 1/4-20X3/4". The shank is fully threaded and the head is 1/2" in diameter. There is a lock washer and 1/4" thick nut on the inside.
    Tim
    • Peter R.
      • June 19, 2011
      • 233
      Tim, Thank you so much. I couldn't hope for a better, more detailed answer than that. That's excellent, too, because Richard Fortier has screws exactly that size. If I can every help you, please don't hesitate to ask.
      Thanks again,
      Pete
      Pete
      1954 Corvette #814
