Need some help on the diagnostic procedure I should use to determine if I have a battery or a starter problem. Here's the situation:
- 66 small block, 327/300
- 9 year old rebuilt starter, approx 30k miles since it was rebuilt.
- approx 7 year old battery with disconnect switch mounted on positive terminal
- when I turn the ignition (engine cold or hot), it turns very slowly and may or may not fire up
- I have cleaned the battery terminals and fully charged the battery. Battery measures 12.5v after charge.
