Is this hub(1963-66)placed the right way the hub is bolted on the steering shaft? - NCRS Discussion Boards
  • Claus S.
    • December 30, 2010
    • 414
    So i have the spokes on the steering wheel correct
    I ask here because it is freezing cold outside and i do not have a heated garage
    Re: Is this hub(1963-66)placed the right way the hub is bolted on the steering shaft?
    [ATTACH=CONFIG]44123[/ATTACH]
    Roger -
    Nope. See the photo below - there's a chisel mark on the hub which should be at 12 o'clock with the wheels straight ahead, which is to be aligned with a similar chisel mark on the end of the steering shaft. With the hub in the straight ahead position, the hole for the horn contact brush will be at about 1:30.
    • Claus S.
      • December 30, 2010
      • 414
      Thank you John Now i see the mark after you told me
