Oil recommendations to use in a 427? - NCRS Discussion Boards
  • Shawn W.
    • December 17, 2012
    • 23
    Have been doing some research about the best oil for flat tappet cams and quickly found myself reading over 1,000's of opinions but little data. Some suggested using a 20W-50 off road oil because of the zinc level. Another recommend using a synthetic and adding ZDDP, and another recommended just going with a synthetic. Rather than dig through more opinions I figured I would seek the expertise of NCRS members. What say ye?
    While I am at it, does anyone have any suggestions/recommendations about using an oil additive like Z-max in an older motor?
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Oil recommendations to use in a 427?
    Duke, be gentle. He's new here.
    Shawn-
    read this starting on page three for some real facts:
    Zmax at best is of no benefit and uneeded and at worst the ultimate example of snake oil.
    • Michael J.
      • January 27, 2009
      • 7073
      Shawn-
      +1, only at break in of a new motor would you need more ZDDP than in the recommended oil.
        • 15610
        Hey, I'm letting you guys respond to these oil inquiries, now, and your response is spot on. Thanks!
        • Shawn W.
          • December 17, 2012
          • 23
          I appreciate the quick response and education.
          • Michael J.
            • January 27, 2009
            • 7073
            It's really pretty simple, except I am always amazed at the people who don't know. I had one of my old cars at my friend's shop (an NCRS member and as old as I and has owned and worked on many C1-C3 Corvettes and an experienced mechanic for old cars), and told him to change the oil and filter. He looked at my Shell Rotella 15-40W CJ-4 oil and said, "you don't need to use the fancy synthetic stuff, any 10-30W will work fine". I had to explain to him too.
            • Paul H.
              • September 30, 2000
              • 678
              Z Max is Snake Oil. Save your money.
              Shell Rotella 15W 40 will work fine. Walmart sells it cheap.
                • 15610
                Walmart's house brand 15W-40 CJ-4 is less expensive than the national brands, and I will buy it if it's in stock at my local Walmart, but often it's not on the shelf.
                • Ronald F.
                  • September 29, 2012
                  • 135
                  So would Delo 400LE 15W-40 be a good choice for the '67 L71 engine? And would use of these CJ-4 oils still require changing the oil every 2 months or could we go longer?
                    • 15610
                    Yes, That's a CJ-4 oil... says so right on the bottle. right?
                    You change your oil every two months? My God, where does this stuff come from?
                    • Michael J.
                      • January 27, 2009
                      • 7073
                      Wow! Every 2 months? Mine is changed every year, whether I need to or not.....
                      • Pat M.
                        • April 1, 2006
                        • 1575
                        We need a "Here's what oil to use in your vintage Corvette" permanent sticky.
                        • Ronald F.
                          • 135
                          Duke, it says so right in the original owners manual: Every 60 days or 6k miles. It's confirmed in the Service Manual. I know...I had to check it 3x before I finally believed my eyes. Apparently, the L71 is prone to producing acidic oil during cold starts. It also calls for 10W-30 oil which is why I'm wondering if the 15W-40 viscosity oil would be OK.
                          I have been using non CJ-4 oil, Castrol 10W-30, for the past year. I drive it weekly if weather permits. I could use some expert, experienced advice, particularly from other vintage solid-lifter engine owners.
                          Ron
                          • John M.
                            • June 27, 2010
                            • 179
                            I had my 67 BB at Hendrix Performance shop, while there they did a oil change and used the Mobil 20W-50. I think I'll stick with that recommendation next time I change the oil.
                            • Robert M.
                              • April 30, 1999
                              • 415
                              Shawn
                              Read Duke's many posts on this subject. Follow his advice and save your money.
                              Rob
