I was testing my headlights and noticed that one of the high beams on my '61 would not light. I checked the voltage at the two-pin receptacle and found it to be about 9.6 volts. The bulb was burned out and I replaced it but I assumed the voltage at the receptacle would be closer to 12 volts. Is 9.6 volts normal?
Voltage at high beam headlight
Re: Voltage at high beam headlight
Art, should be battery voltage, make a check of wiring at the high beam switch, maybe a bad connection, and any other connector pigtails that maybe involved.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
