HELLO, HERE IS A QUESTION THAT MIGHT STUMP YOU!
I HAVE A 1965 "FUELIE". (MY CAR WAS BUILT WITH NO TRANSISTOR IGNITION) THIS IS AN ALL ORIGINAL SURVIVOR WITH VERY FEW PARTS CHANGED SINCE NEW. THE CAR WAS BUILT ON FEB 23, 1965. THE ALTERNATOR IS DATED FEB. 5,1965. IT LOOKS LIKE IT HAS NEVER BEEN OFF THE CAR. THE PART NUMBER ON MY ALT. IS 1100693 AND IS A 37 AMP WITH A DEEP V PULLEY. THE O.D IS 2 -7/8" THE SPEC. BOOKS CALL FOR A 110696 ALT.
WHEN TRYING TO BUY THE CORRECT GM ALT. BELT FOR JUDGING, THE CATALOGS AND BOOKS CALL FOR A GM#3843162. THIS BELT DOES NOT FIT. IT IS TOO BIG. I BELIEVE THAT IT IS TOO BIG BECAUSE MOST FUELIES HAD 42 AMP,
3- 5/8" pulley which would require a bigger diameter 55" belt.
I WAS TOLD THAT THERE WAS NO NEED FOR THE ASSEMBLY LINE TO INSTALL A 42 AMP ALT ON MY CAR WITHOUT TRANSISTOR. SO IT GOT A DEEP " V " , 37 AMP UNIT.
THE ONLY BELT THAT WILL FIT ON MY ALT. AND ADJUST PROPERLY IS FOR A 1966-1967 427 W/AC. THAT IS A PROBLEM FOR JUDGING...
ANYONE HAVE KNOWLEDGE PLEASE. THANKS. JIM
