I am needing a rebuild for a 69 427/400 with 4 speed and 3.70 posi. This was prompted by a leakdown test that looked like this
1 3 5 7
35% 18% 16% 23%
2 4 6 8
18% 43% 33% 30%
The engine is out of the car, and the builder has done an inspection. It was rebuilt in the distant past. It had newer valves and apparently just a hone- no overbore. The deck was flat
and will not need to be redecked. He said the heads would need a light shave. No obvious cracks in the heads or block.
He said the oil came out clean, but there was a lot of metal dust in the oil pan. The cylinders were scored, and would catch a finger nail. The bearing journals were pretty ate up, he said they were radially scored. He thought the wear on the pistons and bearings was from metal shavings getting fused into the moving parts.
He recommended hot tanking it, a torque plate rebore .03 over, replace the pistons, bearings, and valves, grind the crank, and balance it out. The rods looked good he said they were worth keeping.
He said the camshaft showed a little wear, and could be kept, but he wanted me to think about a roller cam. He said it would keep the idle lope, but give better performance.
I also asked about boring to .02 over, to try and preserve as much of the block as possible, but he said the pistons may be hard to find for the 427
Any thoughts on the camshaft choice, or other questions I should ask? Thanks
1 3 5 7
35% 18% 16% 23%
2 4 6 8
18% 43% 33% 30%
