63 Master Cylnder Leak - NCRS Discussion Boards
  • John V.
    • October 14, 2008
    • 9
    Can my original master brake cylinder rebuilt?
  • Paul J.
    • September 9, 2008
    • 2091
    Re: 63 Master Cylnder Leak
    Absolutely. It's an easy job. However, you must check and see if there is any pitting in the bore and if so, how bad is it. In all of the ones that I have done I was able to clean up the bore with a hone. If the pitting is too bad, then you will need to send it out to have it sleeved. I would only do this as a last resort. Everybody sells rebuild kits.
    Paul
