65 Temp Gauge - NCRS Discussion Boards
65 Temp Gauge
  • Brenton M.
    • May 31, 2006
    • 66
    65 Temp Gauge
    I have a bad temp Gauge in my 396/425 corvette, Is it possible for me to change this gauge without removing the dash cluster? Please Help!!
    • 6940
    Re: 65 Temp Gauge
    Brenton,I think you'll find you will need to remove the dash. it will be a lot easier. there just is not enough room. the gages come out in pairs.
    • Rob M.
      • April 30, 2003
      • 657
      Re: 65 Temp Gauge
      If you are sure that it is the gauge, I would take the time to pull the cluster. I believe you'll be happier in the end and be able to take care of anything else that needs attention "while your in there" kind of thing.
      Rob
      '66 327/300 Regional Top Flt
      '08 6 speed coupe
      • Wayne P.
        • January 23, 2008
        • 444
        Re: 65 Temp Gauge
        Brenton if you have small hands shouldn't be a problem getting it out. I took mine out by placing longer bolts
        in were the dash screws were. Took out the oil line then pulled cluster out enough to get tack and speedo cable off. Also trip cable
        Then it was no issue. Agreed at this point you may as well take cluster out and replace all bulbs. Don't forget to take driver seat and steering wheal column out as well. Makes job go much faster also make sure power battery cable is taken off.
        When I did take mine out I noticed I didn't have a capacitor on the brown wire for the radio. I purchased everything from Long Island Corvette very happy . Putting cluster back in next week. Good luck.
