After a couple of months with the front end out of my '72 for restoration I'm finally in the process of putting it all back together. The car has been supported at the front frame jack points on 12" of wood on each side. This afternoon, with some help, the process of putting the restored, re-bushed A-arms back on began. We got the left one on the car and found the front edge of the A-arm rubbed the front of the cutout in the fiberglass fender liner when the arm was raised about 2 inches. I installed the shims packs as they were when I took the arms, still rubbed. I compared the current situation and the spacing is different in the "hole" than it was before I installed the new bushings and ball joints. My question is, is it possible that, since the car has been on blocks so long with the engine in, etc. is it possible the frame or the body has flexed? If so, will it re-align when I get the weight back on the wheels. Any suggestions?
Thanks guys. Right side starts tomorrow.
