Re: Soda blasting and paint problem
Paul,
The acid-base comment might be the key if using a water based paint but as you mentioned with solvent based paint if the surface is prepped properly the soda blasting should have no affect.
The media (sodium bicarbonate also known as baking soda) is very water soluable and also forms a basic solution as demonstrated in removing residue from a battery.
I would think that after removing most of the powder residue a through washing with water would leave a clean surface for the next step, paint prep.
As with most media blasting removing ALL the dry media is very difficult and pretty much impossible So with the water wash I would think a very clean surface would be easier to achieve.
My 2 cents.
Paul,
My 2 cents.
