Guys,
I just bought a 67 327/350 vert which is a mostly numbers matching car except for an added MSD ignition. It has the correct Holley carb on it. The engine was supposedly rebuilt in 2004 and in fact runs very well in all regards except that the engine runs rich pretty much all the time. Removed spark plugs are black with soot but mostly dry and they do not seem to be oily. The engine does not really smoke especially does not smoke blue as if it was oil fouling. The previous owner reported that the engine ran rich so he had a MSD ignition system installed which seemed to stop the spark plug fuel fouling. Obviously one of my first tasks is to get that MSD stuff out of there. The original dist came with the car so it's getting rebuilt to go back in. I have not done a compression test yet, but I suspect the Holley is at fault at this point. I have a good deal of experience with the Qjet, but not so much with the Holley. I suspect that possibly the power valve is blown and maybe the float levels are off some. I am hoping some of you may have some ideas and then a recommendation for the best place to send it for overhaul.
I really appreciate any ideas you may have.
Brad
Brad
