1968 shroud bracket #3935570--available original or reproduction? - NCRS Discussion Boards
  • Henry J.
    • November 1, 1999
    • 457
    Re: 1968 shroud bracket #3935570--available original or reproduction?
    Yes, mine as well.
    • George W.
      • May 31, 2000
      • 543
      Photos below are from a known original '68, late build, 427/390, 4 speed, no a/c.
      Looks just like Dale's and just like Corvette Central's used original.
      Below are photos of '69 big block bracket:
      G
      • Brad Hillhouse (37766)
        Bringing this old thread back to life as I need the same fan shroud mounting bracket for 1968 L71 GM3935770. Anyone have a used one laying around collecting dust?
        Brad
        • Jeff P.
          • 797
          Question, I have read that a 68 big block shroud is the same as a 68 small block with Air. Would this be correct ?
          68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
          2014 Arctic White Z51 Vert. (Wifes)
            • 43193
            Jeff------
            They were similar but not the same. However, the SERVICE shroud assembly for the 427 was the same as the SERVICE shroud assembly for small block with C-60 and/or M-40.
            • Jeff P.
              • 797
              Thank you Joe.
              • Anthony S.
                • September 3, 2007
                • 107
                Originally posted by Scott Kohn (3030)
                It is still in development, but we currently have an original one for sale on our new CC Swap Meet site. You can view it here or visit http://www.corvettecentral.com/swap-meet/
                Is the radiator shroud bracket in production? I checked the Corvette Central website and didn't see it listed.
                There are two kinds of friends; the friend you call to bail you out of jail and the friend sitting next to you in the cell saying "Damn, that was great"!!!
                • William H.
                  • January 11, 2010
                  • 65
                  You can make one from a small block bracket but it will take some work. Cut the dip out of the center, weld in the hole. Make side skirts and weld them on the two ends. then cut off the skits off at a angle. I've done it but it took about 5 1/2 hours.
