C3 Body Spacers RH and LH - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 474
    In the assembly manual for a 1971 it shows the body spacer forbody mounts 2 and 3 on both sides as part # 3973886 and body mounts 1 and 4 on the right hand side with the same part number but on the left hand side it shows part # 3973897 for the spacer for body mounts 1 and 4. What is the difference between them.
    Thanks in advance.
    Sheldon
  • Richard R.
    • August 31, 1988
    • 98
    Re: C3 Body Spacers RH and LH
    Sheldon, there is a step in the 3973897 spacers that helps to center the body on the frame. When you take them out its easy to see the difference. Hope this helps
